LR Baggs Anthem battery pack keeps coming loose http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=52184 |
Author: | James Orr [ Tue Jul 16, 2019 8:53 am ] |
Post subject: | LR Baggs Anthem battery pack keeps coming loose |
The battery pack of my LR Baggs Anthem doesn't want to stay in place. Saturday night I decided to ditch the factory adhesive in favor of double stick tape and still no luck. It was jostling around inside the body during a rehearsal Sunday morning. I'm installing it in the upper left shoulder of the guitar. Right shoulder is a cutaway. My thoughts have been to (a) stop trying to defy gravity by adhering it to the side of the right lower bout, and/or (b) try some kind of mechanical bond like a magnet instead of adhesive (just not sure if magnets will mess with the battery or signal). |
Author: | Mike Collins [ Tue Jul 16, 2019 10:47 am ] |
Post subject: | Re: LR Baggs Anthem battery pack keeps coming loose |
Loctite ca. Mike |
Author: | Freeman [ Tue Jul 16, 2019 11:11 am ] |
I use gel superglue to hold the velcro to the inside of the guitar. |
Author: | Tim Mullin [ Tue Jul 16, 2019 12:40 pm ] |
I’ve installed a whole bunch of these, but rarely stuck to the guitar side, rather to the back or neck block. The LR Baggs pressure-sensitive adhesive is pretty aggressive — has to be to stay in place while separating the Velcro. I suspect the curved surface of the side might be at least part of your issue. I assume you cleaned the mounting surface? Sent from my iPad using Tapatalk |
Author: | Aaron O [ Tue Jul 16, 2019 8:27 pm ] |
Once I started "finishing" my neck blocks with CA, no issues with velcro sticking to it. |
Author: | James Orr [ Tue Jul 16, 2019 10:04 pm ] |
Freeman wrote: I use gel superglue to hold the velcro to the inside of the guitar. Part of me worries about damaging the side if I ever want to take it out... The other parts wonders if I ever will. How do you apply it? Is it just a dot? A line of glue? Surrounding the perimeter with it? |
Author: | dberkowitz [ Thu Jul 25, 2019 2:27 pm ] |
I always install on the side and never had a problem. You do need to blow out the area, wipe it down with a tack rag and clean it with denatured alcohol. |
Author: | Mike OMelia [ Thu Jul 25, 2019 5:33 pm ] |
You have GOT to clean the area completely with DNA and let dry. Problem is worse with oily woods. Clean, then clean again. Let dry. Then do not let your fingers touch the area. I have successfully attached to coco and African Blackwood using this approach. |
